conduit run schedule not working
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hello, I am trying to make a conduit run schedule but it is not working. I tried following the directions here: https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/R...
But it does not work. For one, it is not an actual Revit "Conduit Run Schedule" it is a Multi-category schedule.
Secondly, it claims that:
"In the schedule, you will see lines which do not have the Run Name filled out. These are the runs themselves. Select the element in the schedule, and hit Highlight in Model."
However, there are no blank lines in my schedule once I do this, not to mention there is a ton of elements that land in this schedule because it is Multi-Category schedule and I dont know what to filter out because you cant select conduit runs which is what I wanted in the first place so the "answer" Doesnt work at all. Now. I have all my shared parameters created and everything but they are not showing up right in the conduit run schedule. What am I doing wrong? Please advise. If you could make a video that would be most helpful!
Thanks!
