Revit MEP Forum
Conduit Rolling Offset Problem
9 REPLIES 9
Message 1 of 10
nsalazar
1331 Views, 9 Replies
When drawing conduit rolling offset (say conduit at 10' the other at 9'-6" and offset when connecting the conduit revit auto adds a box to make the elevation change connection instead of rolling the bend. funny thing is it works fine if I make a generic project
9 REPLIES 9
Message 2 of 10
piotr.bocian
in reply to: nsalazar
That is because in conduit type properties you have selected bend fitting family which has defined inside family part type Junction Box Elbow.
If you need have bend select fitting with Elbow as part type.
Message 3 of 10
nsalazar
in reply to: piotr.bocian
Thanks  for the reply!,
Your suggestion helped get rid of the box but the transition still doesn't work properly (see attached) the second image is of a correct rolling offset done in a new centralCapture.PNGCapture2.PNG
Message 4 of 10
nsalazar
Just a quick question also how do I go by to reload these fittings maybe reloading them will fix the issue but I cant remember how to do it.
Message 5 of 10
piotr.bocian
That's because Bend Radius is to big to the offset. Bend Radius you can set up while sketching on ribbon.
Message 6 of 10
piotr.bocian
I'm not sure what you would like to do, but to reload family you have some ways:
1) Right click on family name in project browser and select Reload
2) Open family in family editor and load into project
3) Load family while placing
Message 7 of 10
nsalazar
I once created a central but forgot to make sure it was the electrical template so none of the conduit or cable tray came so I had to load it manually, but I have slept since so I cant remember how I did that. Anyways the bend radius is not the issue. Ill keep trying thanks for your help
Message 8 of 10
piotr.bocian
To transfer setting, system families and associated loaded families from another project use Transfer Project Standards:
http://help.autodesk.com/view/RVT/2019/ENU/?guid=GUID-2A49FE80-1B07-4C95-A0FE-42CE2001F3C2
Message 9 of 10
nsalazar
This fixed the issue but I would still like to know what caused it. Someone from our team must of modified the conduit family fittings or something.  Anyways thank you for your help I appreciate it.
Message 10 of 10
diacreek
want to make it fitting to fitting at a lot of instances. For example, for Victaulic system, if remove one fitting such as an elbow from the system, a lot of cost will be saved.
For small bore conduits, none too many concerns.
