Conduit bend radius tag
How to make conduit bend radius tag
Secttor
hi @Anonymous
you need to load the Conduit Fitting Size Tag > edit the family > edit label and add you shared radius parameter in order to have it represented.
hope it helps
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
fabiosato
You can´t create a tag that access Bend Radius parameter value, you will need to create a Shared Parameter and make it equal to Bend Radius, use the Shared Parameter in your tag.
Fábio Sato
