Conditional Formats in panel schedules
dtiemeyer
Advisor Advisor
dtiemeyer
Is it possible to use conditional formatting in Panel Schedules?
For example I created a project parameter that displays in the panel schedule that I would like to show up red if another value is greater than 0.
Is this possible in panel schedules? or only in normal schedules...
My other CAD is a Cadillac and I like to Revit to the Max!
CoreyDaun
Conditional Formatting is only available in normal Schedules. Create an Electrical Circuit Schedule, grouped by Panel Name, sorted by Circuit Number, and then set your Conditional Formatting.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Alaaeldin_Alsahli
Unfortunately you cannot add conditions for Panel Schedule. You can change the cell shading by editing the template manually but it will affect all Panels' schedule that are using the modified template.
The best way is to send wishlist request to Autodesk Development team
Here is a link for that
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=1109794
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
