Combining Yes/No Parameters & Lookup Formulas
adrian.fern
adrian.fern
I have a revit family item (See attachments) that has multiple types, the dimensions are all driven by a lookup table (See attachments). The product is available either with or without magnetic contacts, which i currently have set as Yes/No parameters.
What i would like to happen is that the Product ID within the Identity Data Section changes when the Yes/No parameters change, can anyone advise on how to go about doing this?
Many thanks
L.Maas
Probably I would create a new number parameter with a value of 1 and 0 (Yes and No). You can use the Yes/No parameter to control this. The number parameter you could use to be a part of a lookup formula.
Louis
Please mention Revit version, especially when uploading Revit files.
