Thanks, but I can choose every view template which I have and the discipline is not changing stays grey. 😞
I uploaded the file so you can have a look. Please me help me out. 🙂
Change the setting in the view template and it will change in all views controlled by that template or remove the template from the view.
Also consult the person in charge of your models.
If you scroll down in the properties pallete you will find an entry for view template - click it and the template will open up to allow editing.
Note however that if you edit the template then ALL views which use that template will be affected.
The file that you uploaded has had the template removed from the view and settings are no longer greyed out.
