hello,
I am working on a BIM project in the cloud - design HVAC.
I work in ceiling plan.
the architecture which includes the hanging ceiling obscure the construction beams which above them.
I want to see the construction beams before the ceiling (and in red :)) and below it the hanging ceiling. how do I do that??
I can work in "floor plan" - but then I don't see the ceiling...
or change the view range in "ceiling plan" (and again not to see the hanging ceiling)
can you help?
Solved by AutoCAT95. Go to Solution.
I would try go to Visibility/Graphics and set hanging ceiling transparency so i can see beams behind it.
To make beams red you can change line styles.
thanks,
i was sure that i tried it...
but as simple as it is - it worked...
BTW - the coloring of the constructional elements didnt work... but its less important...
