Cant change view range, detail level or visual style in plan view
Message 1 of 8
Hi
I cant change the view range, detail level or visual style in any of my plan views in my project. After a quick search on here someone suggested that there must be a view template applied and to try changing it but i have done that and still no luck. Any suggestions?
Replies (7)
Message 2 of 8
RobDraw
Try again as that is the most likely culprit or post the file.
Rob
Message 3 of 8
Hi Rob
I've closed Revit down then reopened the project and changed the view template and still no luck
Message 4 of 8
RobDraw
Without more information, it's only a guessing game. Please post the file or just the portion in question as requested.
Rob
Message 5 of 8
Unfortunately I can't upload the file as we are on a non-disclosure agreement with the customer 😞
Message 6 of 8
RobDraw
Change the view template to none and see if you can change them.
So far, you have provided a very general description. Without the file or a detailed explanation, including screen shots, all we can do is guess.
Rob
Message 7 of 8
@Anonymous wrote:
Hi
Change the View Template to None for those views you want to adjust.
Message 8 of 8
Changing it to None fixed it. Thanks
