Cannot Open IFC File... Not Responding
JLeighton
Observer Observer
JLeighton
Observer
Observer
I received and IFC file from structural and I cannot seem to open it.  I have assigned a template for IFCs in "IFC Options" but with no luck.  I tried linking the IFC as well and it did not work.  When I try to open the IFC it slowly creeps up to about 80% loaded and then the progress bar disappears and I have intermittent waves of Revit "not responding."  I am then stuck in this not responding limbo and nothing ever comes of it.  Any ideas?  I am working in Revit 2016. I am unsure what Revit the IFC was made in but I did not think that mattered when it comes to IFCs.  I thought an IFC file was the only way to achieve backward compatibility with Revit.
EKey
How big is the IFC file?
Opening an IFC file takes much longer than a Revit model with the same size. Give your computer several hours to open the file.
JLeighton
Observer
Observer
The IFC file is 34.8 MB
Jesse Leighton
MEP/BIM Coordination Specialist
[cid:image001.png@01D1FC7A.DD356A10]
The Richmond Group 77 Main Street Hopkinton, MA 01748
D 508.589.7727 * T 508.435.9700 * C 508.380.7152
ExchangeDefender Message Security: Click below to verify authenticity
https://admin.exchangedefender.com/verify.php?id=u97CC99E012454&from=jleighton@therichmondgroup.com
EKey
Opening the file can take hours. Give it a try.
fabiosato
You can try to use Solibri IFC optimizer, it reduces the file size, then opening the file becomes faster.
Depending on your hardware it may take a long time, once I had a file that after opening became 600MB revit file, took around 3 hours to open.
Fábio Sato
