Cannot Create Spreadsheet after using BIM Interoperability Tools Cobie Extension - Multiple Errors
vibhupathak1
vibhupathak1
I have been getting numerous errors when trying to create a spreadsheet after assigning and adding cobie data to my project. Is something wrong with the way the project has been setup?
Using Revit 2020.2
with an up to date BIM Interoperability Tools addon.
Something to note also is that I have just noticed my Parameter Mappings tab on the Cobie Extension is missing the inputs. Shown below.
<html><p><center><h1> COS-CBG-XX--XX-M3-MEP-00001 Error Report (05/09/2023 16:30:56) </h1></center></p>
<p><table border=on> <th style="width:'50%'; vertical-align:top;"> <center> Error message </center> </th>
<th style="width:'50%'; vertical-align:top;"><center> Elements </center> </th>
<tr> <td style="vertical-align:top;"> Failed to export.: System.Exception: No parameter mapping was found with the root parameter 'COBie.Facility.Name'. Could not get value to export at ADSK.BIT.COBie.Revit.API.ExportValueUtilities.GetExportParameterValue(Element e, String rootParameterName, ParameterMap docParameterMap, SettingManager settings, List`1& errorParams, String defaultOverride, Boolean overrideZero, Boolean overrideNegative) at ADSK.BIT.COBie.Revit.Shell.CmdExport.GetValueParamWithNullValidation(List`1& validation, SettingManager settings, ParameterMap docParameterMap, String sht, Element e, String rootParamName, List`1& errorParams, String defaultOverride, Boolean overrideZero, Boolean overrideNegative) at ADSK.BIT.COBie.Revit.Shell.CmdExport.CollectFacility(SheetModel sheet, Document revDoc, SettingManager settings, Boolean exportAttributes, ParameterMap docParameterMap, List`1& validation) at ADSK.BIT.COBie.Revit.Shell.CmdExport.Execute(ExternalCommandData commandData, String& message, ElementSet elements) </td>
<td> </td> </tr>
</table> </html>
JasonKunkel
There should be something in your Parameter Mapping dialog box. It looks like the settings may have become corrupted. Two things to try:
In the SETUP dialog, hit SAVE AND CLOSE again to try and "jumpstart" the project setup.
If that doesn't work, start a new blank model, and setup the project in COBie like normal. Confirm that you see something in the Parameter Mapping dialog. If you do, export those settings to an XML file. Then in the "bad" model, import those exported settings, but just the Parameter Mapping settings. This might overwrite the "corrupt" settings with a good batch.
Jason Kunkel
Senior Practice Manager, Architecture and Engineering
LinkedIn
