- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I cannot assign my electrical panel to a distribution system using the residential 120V panel from the autodesk library. I am trying to select one of the default distribution systems(120/240V or 120/208V) that are normally available in the electrical template. I have searched and cannot find anyone else to have this issue so I think it is a software glitch that needs an update and this only applies to revit 2021. A bit of background below on what i have done so far.
I have just installed revit 2021 and have the new as well as old families and templates. I performed a fresh install of the new imperial libraries and templates. Everything is fresh out of the box. I have checked all combinations of loading families from library and loading from older versions again using default autodesk revit families and templates nothing has been modified.
