Can't figure out, "Can't rotate element into this position".
ColtonHaney
Message 1 of 11
ColtonHaney
I have a family for a 3/4in compression fitting that I cannot get to rotate in section.
I have tried:
-  turning off "Always Vertical"
-  turning on "Work-Plane Based"
-  copying the geometry into a new family
-  completely redrawing the geometry from scratch in a new family
-  modeling it as a line based family
I could successfully host it to a reference plane and rotate it by rotating the reference plane. However, when doing so the element jumps across the model and I have to track it down and relocate it in it's new orientation back to where I placed it originally. This solution is also not ideal as having a ton of reference planes (one for each element) will be extremely cumbersome to work with.
If anyone has any ideas or solutions, I would greatly appreciate it. Thanks in advance!
(Attached is the family that I am having issues with.)
Replies (10)
Message 2 of 11
dmiller_SCE
If you want to free rotate the family in question with the least effort, then change the family category from generic model to a category that allows free rotation in the project, like pipe fittings, conduit fittings, mechanical equipment, or something similar.
Message 3 of 11
Model it using Mechanical Equipment template, check Always vertical, do not check Work Plane, then you can rotate it however you want in any axis.
Message 4 of 11
acatonHL59J
i have an OOTB revit pipe fitting family that will not allow me to rotate it about the axis of the pipe. Always vertical is not checked, nothing seems amiss with the constraints. It simply will not rotate except at 90 degree increments (need it at 22.5). I can draw a vertical segment of pipe, then from the upper connector draw another section of pipe at the angle I wish to achieve and revit 23 snaps it to a direction that is orthogonal to the coordinate axis.  Or i draw a vertical section, draw a horizontal section and use the extend to  tool or the fillet tool and it does the same thing. I even tried letting it draw the way it wants to and rotating the fitting after the fact about the center axis of the vertical pipe, that's when i get the error. How would I fix these issues?
Message 5 of 11
bjones
Observer
Observer
thank you!! that worked great!!
Message 6 of 11
acatonHL59J
it's already a pipe fitting. it won't rotate. and turning  it into a mechanical equip family won't allow the filters set to work correctly. it needs to remain a pipe fitting - so why doesn't it rotate? what would prevent it acting like every other elbow?
Message 7 of 11
RSomppi
Have you tried checking "Always Vertical"?
Message 8 of 11
acatonHL59J
yeh, it came that way oob, i unchecked it to see if that helped. it didn't. so i rechecked it and played the uncheck recheck game on every box available. not sure why it's being such a pain. the rest of the fittings in the box work just fine. it's just this one (the one i need, of course).  It's a standard 90degree elbow. there's absolutely no reason i can see that it should behave this way. all the other 90 degree elbows work just fine in the package. I've tried turning off/on every setting that can be in the fitting. i set all the check boxes to the same settings as working elbows, too - no joy.
Message 9 of 11
dmiller_SCE
@acatonHL59J I downloaded the family you provided and checked the always vertical option, and it works just fine on my end.
Message 10 of 11
acatonHL59J
that's truly odd. didn't work a lick for me.
Message 11 of 11
flaks
Mirroring the object on some axis did the trick for me.
