Revit MEP Forum
Branch Panel multi-phase ircuit number problem
4 REPLIES 4
570 Views, 4 Replies
I've got a problem which I was trying to solve for the past couple hours. Tried to find something on forums, but unfortunately I was not able to.
The problem I bumped into is shown in the attachment. I'm using a distribution system 230V/400V, and I don't need to show a correct phase distribution in schedule. So I was wondering is it possible to make numbering in scedule not by poles, but by just a place in the panel ( like 1-phase circuits).
I could't fix it in the "Edit Template", "Electrical Settings/Circuit Naming". I made it work somehow how I wanted, by changing parameter, but it's inconvinient, because I couldn't make an automated number parameter. Only as "Text", which means I have to write every number by hand, and it's really inconvinient, when you have a lots of circuits in a panel.
Also I'm using the latest REVIT 2021.
Hope you guys can help me.
Thanks!
Labels (1)
4 REPLIES 4
pteague
To my knowledge, the only way to do this is to use a switchboard family and not a panel family.
Multi-pole circuits in panels always show all the poles they are connected to (P-1,3,5).  The switchboard families only use the position in the panel for the circuit number (P-1).  This is an internal Revit thing that you cannot change.
DBEGGGPZUZ
in reply to: pteague
I have the same desire to show a multi-phase circuit (3 pole) as a single digit circuit number.  As shown in the snippet.  The snippet is from Autodesk help (F1) and searching 'Renumber Indexes'.      That is exactly what I want and it appears to be down on a panelboard and not a switchboard template.
Help!!  thanks
scott_dakin
If you use the custom circuit naming tool in Electrical Settings you may be able to get what you want. It's newly added functionality.
DBEGGGPZUZ
in reply to: scott_dakin
Thanks. Custom seems to get the multi-pole CB to be assigned a common number.
