Bottom of Duct is Reporting Bottom of Insulation
MaxChilds
MaxChilds
When I schedule a section of duct that is ready for fab, it reports the bottom of the insulation instead of the bottom of the duct. If I just tag the duct with elevation it comes out right. If I take the insulation off, then it reports right but I need the insulation for the hangers. Is there a way to change this in Revit?
Max
Add a calculated value parameter = Bottom of Insulation - Insulation Thickness?
robert.klempau
Hello @MaxChilds ,
You could use a TAG that shows the Bottom of the Duct like I did in the picture below or use the Spot Elevation.
Is that what you want?
just open the TAG family "M_Top Elevation Duct Tag.rfa" from the library an change the Label parameter to Bottom Elevation.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Kind regards,
Robert Klempau
Senior Consultant AEC
Cadac Group AEC BV
MaxChilds
ToanDN,
That is what I was looking for.
Thanks.
