I've following questions :
Problem 1)
I've made different duct sytems : supply (red) and return (green) air. The vertical supply air duct is under the horizontal red and green duct, and should be represented with a dashed line (like the vertical green duct).
I've made a proper view template with model display "hidden line" and a filter which only overrides the color and weight of the lines. The checkbox 'Draw MEP hidden lines' (Mechanical) is activated.
Why is the supply duct sytem not represented with a dashed line? How to solve this?
Problem 2)
In an architectural model, i drew two model lines (linesyle = hidden line) which should represent a beam.
The architectural model is linked to a hvac mep plan.
The same lines are not represented as dashed lines? It's even not possible to select the lines in the hvac plan and to edit with the tool 'linework' (and override the line style). Any suggestions?
Thanks in advance.
Dirk
