Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Blue Electrical Circuit Path under "Edit Circuit" Missing
aszczawinski
Message 1 of 15
aszczawinski
Good day all,
For some reason, I am unable to see the Blue Line associated with a Electrical Circuit via "Edit Path" in REVIT 2020. I have completed 3 other projects in REVIT 2020 over the past 12 months where I was able to see/manipulate the Blue Line. Does anyone know what the Model Category and/or Workset and/or Annotation Category is associated with this is? Many thanks in advance.
- Andruw
Replies (14)
Message 2 of 15
aszczawinski
Hello all,
Wanted to "bump" this post to the top. For my electrical designers/engineers out there, do any of you know?
Thank you,
Andruw
Message 3 of 15
fabiosato
Does electrical interface is checked? You can check in the Options menu.
Fábio Sato
Message 4 of 15
aszczawinski
Where is this located in REVIT 2020?
Message 5 of 15
aszczawinski
Nevermind, I found the "Options Menu"
However, under "User Interface", the options for "Systems tab: electrical tools" and "Electrical analysis tools" are BOTH checked. What should I check next?
Message 6 of 15
Message 7 of 15
aszczawinski
Toan,
That "Blue Line" is exactly what I am getting at - I do not see it in my model for whatever reason for this one project.
I explored this issue with BIM personnel within my company and we were able to determine it is a View Template issue. We could see the Blue Lines in 3D, but not 2D in the Sheet View. We created a Working View from scratch (without any View Templates assigned) and had the same View Range, Phasing and Model Categories and we could see the Blue Line. We are hoping to find the "root cause" sometime soon.
Message 8 of 15
@aszczawinski wrote:
Toan,
Never mind.  Fixing the view template with a a fresh view is they way to go.
Are you saying that after click Edit Path you still don't see the Blue lines?
Message 9 of 15
aszczawinski
For reference:
Message 10 of 15
aszczawinski
Toan,
Yes - please see "For Reference" response that I posted prior to seeing this response.
Message 11 of 15
aszczawinski
Toan,
Yes - when selecting "Edit Circuit" I do not see the Blue Line path.
I figured a new View Template would be the way to go, still curious though what the "root cause" of this issue is.
Message 12 of 15
Can you share the model, or a portion of it, with that view?
Message 13 of 15
aszczawinski
Toan,
I won't be able to share the model but I could share screenshots of the View Template if that helps
Message 14 of 15
Toan,
Lets try that.
Message 15 of 15
jkirk-OMM
I have a similar issue with the blue lines in Electrical Circuits. The portion not showing for me is the actual circuit lines as opposed to the circuit path.
Turn on all of your worksets in the troubled view and try again. If it works, one of them is causing the issue.
I have no idea why, but a workset not related to my lighting fixtures was set to "Hide" and when I turn it on the circuit lines showed up again. I must have set something up on the wrong workset somewhere, just haven't found it yet.
UPDATE: I confirm it was the workset which caused bluelines not to show. The workset apparently had no relation to my view that I could find. I created a new workset and moved all previous objects from the problematic one. Blue Lines are back.
