it has been my experience that Template bloat leads to project bloat.
users wont purge out unnecessary things for fear of the unknown (what if ineed it later) I dont know where to find it because it was always given to me.
users will always do what they are comfortable with.
give them everything they do less. (counter productive.) they dont understand a process if it is not explained to them.
training and set up fix some of these issues.
time is always used as an excuse to not use a direction or a workflow.
it has never been used when a problem occurs. ( I dont have time for this now) in reality you have all the time it takes to fix the issue.
by purging to accomplish a task you tend to remove more than you expected or maybe realize.
try not to get hung up on the project size.
start small and grow the project cleaner and smarter
its good your families are created lean, it helps in the long run.
it is easier to modify less more quickly so start with less and go shopping for what you need as you need it.
create a one stop location for all your resources and point all users to that location.
using multiple files
Templates
Families
Seed Files (Standard Details, Schedules, Legend Views) etc.
these seed files will be accessed as needed to populate your model when needed.
lessens the clutter.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
