Revit MEP Forum
Beginner Question - Sequential Tagging
6 REPLIES 6
eric_messerli
408 Views, 6 Replies
Apologies in advance, I'm pretty new to Revit and I'm learning as I go here...
Is there a way to set up the tagging function to label locations sequentially as I click them in whatever order I choose? For example, if I have 200 data locations across a floor and want to label them ABC-001, ABC-002, etc., but want to select them in a specific/staggered order rather than a sweeping "tag-all".
Is there a setting I'm missing, or even a 3rd party add-on, that would allow me to set up the conditions/parameters of my labeling scheme and then just start clicking through my locations and auto-sequencing them?
Thanks for any advice or tips.
6 REPLIES 6
RobDraw
in reply to: eric_messerli
You're going to need an app for that. There are several that are designed for other things that have this as a tool or you might be able find one just for this.
Rob
Ah ok. Do you have any suggestions I could look into?
iainsavage
The Reordering app which is part of DiRoots One - you can draw lines from item to item and it will renumber based on the sequence of the nodes.
eric_messerli
in reply to: iainsavage
That's it, that's what I was looking for. Very much appreciated!
RobDraw
You're welcome.
Rob
There may be some here that you might also find useful
https://www.imaginit.com/software/imaginit-utilities-other-products/utilities-for-revit
I think some of them are free, but I don't recall which ones.
