AutoCAD Attribute Not Visible
Teresa.KawaguchiGUSLM
I have a CAD block with two attributes. One attribute isn't visible when linked into Revit. All parts of the block are on the same layer. The block is attached on this post. Thanks in advance for any help.
DWG
REVIT
kadmonkee
use the cad file to create a family for Revit CCTV then when you place that family you can tag it and it will pick up the correct info without relying on a linked cad file
you will also need to create a tag to report the family type , name etc.
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
