assembly code for Pipes
menline
menline
hello All,
I have the problem to fill in the correct assembly codes for piping.
A copper pipe can serve as a water pipe or gas pipe, but both have a different assembly code,
But only in the properties of the pipe you can enter the assembly code, i.e. that of copper pipe.
How do you all solve this problem ?
Menno
iainsavage
Most families have an Assembly Code parameter built-in but it is not compulsory to apply a value to it, in fact I've never used it.
hmunsell
make different Pipe Types for there different uses. Double click on the Pipe Type in the Project Browser to edit the Assembly Code for each Type.
Howard Munsell
menline
Yes I thought of that too, but this means a lot of double bend, Tees, etc
fabiosato
You can duplicate the type of the fittings for each assembly code.
Fábio Sato
