Analytical Model Analysis
kohler
kohler
Community Visitor
Community Visitor
Hi!
I recently upgraded to Revit 2022 (from 2020) and I am having a hard time building and analyzing the analytical model built. Up to now I used the dialog that came up when exporting to gbxml, where it was possible to see potential errors, isolate distinct rooms and see their surfaces in an easy manner.
So far I managed to build an analytical model using the tools within the "Energy Optimization" Tab on the Analyze Ribbon. After a lengthy search I could show the analytical spaces and faces created using the "analytical spaces" and "analytical surfaces" schedules. But I am still missing the error reporting and the possibility to isolate / analyze certain spaces in detail, as it as possible using the dialog. Where has this functionality gone? Someone can help please?
Best regards
Christian
m_clough
Keep in mind that there are a few different steps, but all the commands are in the Energy Optimization Panel on the Analyze Tab.
It sounds like you may have created the energy model.  If you are interested in load calculations or energy analysis, be sure to look through the Systems Analysis workflow
Run Systems Analysis | Revit 2020 | Autodesk Knowledge Network
this will allow you to configure analytic systems and generate the reports.
