- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi Revit MEP community
I am creating an air flow schematic layout in Revit 2016 and have all 3 floors of ductwork showing correct values however just 1 extract fan I am using is coming out with no airflow at all even though the connections and values have been set up correctly.
The system comprises of 6 return air valves connected to a fan which extract to the roof
The settings are as follows:
Air Valves
RETURN AIR
PRESET
OUT
FAN CONNECTION 1 (FROM AIR VALVES)
RETURN AIR
CALCULATED
IN
PARAMETER ADDED TO AIR FLOW 'CALLED FLOW'
FAN CONNECTION 2 (FROM AIR VALVES)
RETURN AIR
PRESET
OUT
FLOW PARAMETER ADDED TO AIR FLOW
Any ideas would be appreciated as this is becoming very irritating. (I have attached a partial screen shot showing problem)
Thanks in advance
