Revit MEP Forum
Air Flow In a Duct Tag
9 REPLIES 9
Message 1 of 10
RobDraw
1988 Views, 9 Replies
Is it possible to tag the air flow of a duct riser in a plan view?
I've got a duct tag that is working as expected but it won't pick up the air flow of a riser in plan view. It gets it on section and horizontal ducts on the same system and in the same plan view.
(This is the only place where we put air flows for ducts and it's the only place it doesn't work.)
Rob
9 REPLIES 9
Message 2 of 10
Secttor
in reply to: RobDraw
Hey @RobDraw
Removing the duct that's over it, tag it and reconnect shoud work, isn't it? Smiley Happy
It's not as professional as expected but..except doing as above or moving it to be accessed (and after back to original position) I don't see now an alternative.
Revit MEP - Electrical Certified Professional
Revit MEP - Mechanical Certified Professional
Draftworks.wordpress.com
Message 3 of 10
RobDraw
in reply to: Secttor
@Secttor wrote:
Hey @RobDraw
What? We are talking about a riser (vertical) duct. There is nothing over it, except for itself.
The tag on the riser is working for everything except for the air flow. It's not the model or the tag. It is repeatable in an empty project with a different tag family. I tried a similar situation in a section view. The tag works as expected. There is something about floor plan views that is interfering with the parameter being read.
Here's the kicker. We were able to get it work by making a new formula parameter that equals the flow parameter. Yeah, the same parameter that doesn't get read from the riser.
Rob
Message 4 of 10
Secttor
I knew what you mean with the riser but now it's more clear regarding your worries scenario.
Message 5 of 10
M1k3y2014
Interesting. I hadn't tested this until now and I have the same problem:
I wondered if it could be related to Revit reading the data from the entire length of the riser, somehow. (and then as there are different flows from the outlets, Revit doesn't know which value to choose)
I tested splitting the riser and then I got the value here:
Message 6 of 10
pawel.romaniuk
in reply to: M1k3y2014
Hello @RobDraw
Hello @M1k3y2014
Using Tees in vertical ducts allow "read" flow parameters.
 Please hit the Accept as Solution button if my post resolves you issue
Pawel Romaniuk
Message 7 of 10
RobDraw
in reply to: pawel.romaniuk
No, your solution does not solve my issue.
Rob
Message 8 of 10
pawel.romaniuk
Hello @RobDraw
What do you think about posting this issue on Revit Idee Station ?  At this time Revit does not know which value should be taken from tapped duct on floor plan. In 3D view this tags are working properly.
Pawel Romaniuk
Message 9 of 10
RobDraw
But it does know. We've gotten it to work by making a new formula parameter that equals the flow. It appears to be a bug.
Rob
Message 10 of 10
pawel.romaniuk
Let's try to improve it...
Make Air Flow parameter readable in Tag for vertical ducts
Wrong annotation tag for vertical ducts on floor plan in Revit
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/sfdcarticles/sfdcarticles/W...
Pawel Romaniuk
State of Sustainability Webinar
