ADDING A DELETED PRINT SIZE
I was setting up a project and deleted the wrong print sizes. How can I get the size that I need back as a print option?
In the print dialog, click "setup" in the bottom left corner and specify any size/margin/scaling you want, then save as to keep it in the project.
You can probably pull it in from another open/linked project using transfer project standards too.
Thank you very much.
