Add custom data fields to .MAJ export from Revit
mmckeonXZRL9
Message 1 of 1
mmckeonXZRL9
Hi there,
I am trying to work out how I can add the typeID and InstanceID for each Revit element when exporting to .MAJ. I have built a custom addin to export to .MAJ which is working.
In CADMep I have custom data fields set up with IDs and I want to see these fields but I can not seem to add these to the body of my SaveAsFabricationJob method. Has anyone done this ? Or am i looking at this the wrong way?
Heres my code:
[Transaction(TransactionMode.Manual)]
    public class Command : IExternalCommand
        public Result Execute(ExternalCommandData commandData, ref string message, ElementSet elements)
            UIDocument uidoc = commandData.Application.ActiveUIDocument;
            ICollection<ElementId> selectedIds = uidoc.Selection.GetElementIds();
            if (selectedIds.Count == 0)
                MessageBox.Show("Please select items before exporting to MAJ.");
                return Result.Cancelled;
            SaveFileDialog saveFileDialog = new SaveFileDialog
                Filter = "MAJ Files|*.maj",
                Title = "Save a MAJ File"
            if (saveFileDialog.ShowDialog() != DialogResult.OK)
            string savePath = saveFileDialog.FileName;
            // Create the FabricationSaveJobOptions object.
            FabricationSaveJobOptions saveOptions = new FabricationSaveJobOptions();
            FabricationPart.
            // Use SaveAsFabricationJob to export to .MAJ
            ISet<ElementId> exportedIds = FabricationPart.SaveAsFabricationJob(uidoc.Document, new HashSet<ElementId>(selectedIds), savePath, saveOptions);
            // Compare exportedIds with selectedIds to determine if any elements weren't exported
            List<ElementId> notExportedIds = selectedIds.Except(exportedIds).ToList();
            if (notExportedIds.Any())
                MessageBox.Show("Some elements were not exported to MAJ.");
                // Printing the IDs of non-exported elements to the console
                foreach (ElementId id in notExportedIds)
                    Console.WriteLine($"Element with ID {id.IntegerValue} was not exported.");
            // Collect instanceId and typeId
            Document doc = uidoc.Document;
            foreach (ElementId eid in selectedIds)
                Element elem = doc.GetElement(eid);
                ElementId typeId = elem.GetTypeId();
            return Result.Succeeded;
Replies (0)
