A view template is applied to 4 floors and if I add/change any element in one floor, the changes appear in other floors with the same template applied
fahim.hasan
Message 1 of 9
fahim.hasan
HELP!
I have created a view template named as 'RCP' and applied this RCP template to my ceiling plans level 0 to 4. Whenever I make any changes in any floor, the new changes appear in other floors too. For example: I have 4 switches in level 0 and if I add a switch in level 2, that switch also appear in other level 0, 3,4. How can I prevent this? I want this 4 levels to have the same template 'RCP' but at the same time the changes of different floors will not appear in other floors. Is it possible or I need to make different templates for each floor? Please help.
Replies (8)
Message 2 of 9
RobDraw
Is it the view range extends into the other floors?
Rob
Message 3 of 9
iainsavage
@fahim.hasan  schrieb:
or [do] I need to make different templates for each floor?
NO.
As @RobDraw says, check the view range settings.
Message 4 of 9
fahim.hasan
Hi @RobDraw @iainsavage
Attached the screenshot of my view range of Level 1 below:
I can see the switches in Level 1
However, if I change the Top range to 'Associate Level U/S Level 1' to 2800 and cut plane range 1800, I do not see the switches anymore:
not sure what is going wrong.
If I change the Top range to 'Ex Level 2', I can see the switches again!
I appreciate all your helps.
Message 5 of 9
iainsavage
Typical RCP template view range.
Cut Plane should be below the ceiling level.
Top and View Depth should be at or below the floor above.
Message 6 of 9
Why View Depth is Unlimited. Fix it.
Message 7 of 9
fahim.hasan
@iainsavage
top and view depth offset will not be 0.
Message 8 of 9
iainsavage
They are offset 0 from the Level Above.
Message 9 of 9
RobDraw
@fahim.hasan wrote:
@iainsavage
Why not?
Rob
