in Inventor I can to make this view:
Can I make this in Revit?
thanks
mirko
Solved by craigjonnson. Go to Solution.
Yes, similarly you can in plan view or sections. Within a section, the crop view is normally already generated. In plan view you would need to tick both options for "Crop View" and "Crop Region visible".
Selecting the boundary box, you can adjust this to suit the area you want to crop, then simply select the Break symbol on one of the edges.
Then drag the separated views to where you desire. The break symbol is available as a break family, but this is just a generic annotation and isnt automated when you break up your views.
Its not an exact copy to Inventor, but close to what you might require.
