3d View not displaying correctly?
Message 1 of 8
As per the title, please see attached 2 separate images showing what happens when i cut a 3d view.
if i delete the view and re do it, it then works. however, it is now becoming very very annoying and slowing me down.
is there a way to eradicate this problem?
i have also attached my PC spec.
any help appreciated.
(i have also tried it with graphics acceleration turned off and it still happens)
Replies (7)
Message 2 of 8
ennujozlagam
hello, have you try to install latest updates from autodesk and see if helps. thanks
Message 3 of 8
slawrence
Yes everything is up to date
Message 4 of 8
fabiosato
What do you mean by cut a 3D view? Create a section box?
Fábio Sato
Message 5 of 8
yes, when i cut a 3d view it appears as per the attached. i then have to delete the view and re do it.... sometimes this work sometimes it doesnt.
i have applied various view templates to it also, but it still appears the same just with the view template properties applied.
thanks
sean
Message 6 of 8
fabiosato
The only thing that I can guess is some graphic card issue, did you updated the driver?
Fábio Sato
Message 7 of 8
canberraVNFFQ
Community Visitor
Community Visitor
Hi
I was just wondering if you found a solution for the issue?
Regards
Hooman
Message 8 of 8
cmeehan32M3R
Observer
Observer
We had a similar issue and and went through all the steps online of updating the graphics card, checking hardware acceleration, telling windows to use the RTX card, power settings and more. Turns out it was Revit's camera. Go to the camera setting in a view and set it to a number that makes sense and the view will reset, and the items will appear correctly in 3D.
