2 or more conditional formulas yes/no parameter
simon.carmonaCKE9E
simon.carmonaCKE9E
Good morning,
I am trying to create a basic builderswork family that depending on the type of service it increases or reduces the clearence. I am quite new with conditionals and don't understand how they work in Revit. I have read in the forum different posts but I haven't found the solution. It always return me error. Can you please help me with this. I am trying to specify this:
If it is containment give me clearence 50, if it is not containment but it is Ductwork, give me 40mm clearence, if it Plastic Pipework put 30 clearence...
Thank you,
Simon
PavelAnd
Hi @simon.carmonaCKE9E . Look in the end of your formula. "Pipework(30". You need "Pipework,30,50)))".
You can try this:
if(and(A, not(B), not(C)), 50 mm, if(and(not(A), B, not(C)), 40 mm, if(and(not(A), not(B), C), 30 mm, 0 mm)))
Update: It is better to use "_" instead of a space. in the parameter name.
Best regards, Pavel Plotitsyn.
simon.carmonaCKE9E
That worked perfectly. Thank you Very much Pavel. 🙂
Kind Regards,
SImon Carmona
patil.vaishali
Use formula "if(Containment, 50, if(Ductwork, 40, if(Plastic Pipework, 30, 0)))"
Vaishali Patil
Electrical BIM Specialist
