Hello!
It is a fact that Material management in Revit is a big issue.
Here are some ideas:
- Interface should be remade. It's chaotic. Focus on management. Try reducing pop-up windows everywhere. It should be quick. It looks like a patchwork.
- Material shared parameters created by us should appear on the IDENTITY tab, not inside that little button in the corner that no one sees. Also, the native "Class" parameter should be available on Schedules, cause now it's pretty much useless.
- Let us select more than one material and do things like choose the same pattern for them, change colours and so on.
- Put autofill when typing into a Material parameter field (inside a family, for instance), so I can start typing something and then select what I want on the list.
- Create more columns and filters on the Material list, so we can sort materials by Class and then Names, for instance. Filter them, group them. Let us choose the columns.
- Create a way to MERGE materials. For example: If have triplicated materials that should be 1. I can select 2 of them, click MERGE and choose the one that I want to keep. All elements using those first 2 materials now receive the 3rd material. Simple.
- This would be very useful for fill patterns and line styles.
- Create a warning for deleting a material that's in use and allow us to specify another material that will be applied to all elements using the deleted material, or I can choose to leave it empty <by category>.
- Let us choose patterns as we prefer. Let the background pattern be a Model one.
- We should have more control of the textures. There are some tricks to control it but overall we have to accept whatever Revit does. At least create a way for us to set the starting point and angle of the texture on every surface, and lock it.
- I get the idea behind this Appearance system but I never really use it. It is more annoying than useful, at least to me. Keeping the appearances organised is HUGE task.
- Let us use commas and other symbols on Appearance names.
- Make it quicker.
- Review interface. Reduce the amount of popup windows.
- Put Graphics and Appearance side by side maybe?
- Autodesk should have an online material database synchronized with all their software and we users and mainly companies could contribute to that. Not only with textures, but with proper detailed information (physical, thermal) about each material, that can be used later on schedules, analysis and quantities.
Bonus:
Hire me to have this kind of ideas and UX suggestions 🫶
Haha
Cheers! 😃
