Duplicate a sheet
Duplicate a sheet
Please add the feature to duplicate a sheet - i.e. just right-click on a sheet and go to duplicate without views (perhaps ask for a neme at that point.)
35 Comments
I agree.. I struggle with this every day and wonder to myself why I have to create a new sheet, then duplicate the views, then rename the views, change phase, create references on the previous so I can locate in same spot on new sheet, drag onto sheet, move to same reference location.. yada yada yada..
It would be so easy to just right-click, duplicate sheet and views (as copy), then go back and rename the copied views to whatever you want.. change their phase, then done..
stefan_gokstorp
there is a samll workaround for this. select the sheet you want to duplicate. remoce all views from it right click in the browser window and selcet copy to clipboard. press the undo button (to get the views to your original sheet) press the modify tab and paste from clipboard option and your sheet is duplicated with parameter info just need to add your views
damjanuzelac
We are talking about a $2310/year piece of software that does not have a duplicate command in 2019.
eblackburnEFFVJ
It should be context aware as well, so that if you select a sheet in one area of the project browser, it adds the correct sequential number and keeps it within the same grouping.
Status changed to: Accepted
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
The Factory
alakelele
This has to be a joke, why couldn't we do that ?
We are pleased to say that this has been implemented in Revit 2022.1. Thank you for contributing to the improvement of Revit!
-The Factory
Tarek_K
Status changed to: Gathering Support
elie.accari
Now available in Revit 2022
Tarek_K
alakelele
Thank you guys ! Good community service
petermolloyjnr
https://youtu.be/dzkWPd-lAQY
Hi All,
I show how to duplicate sheets with views on this tutorial using the Autodesk plugin 'sheet copy'. Hope this helps.
Peter
@petermolloyjnr , this functionality was Implemented in Revit 2022. No plugin required.
-Kimberly
samuelsanf
Hi, in the Revit Roadmap we have "Reuse Sheets instead of Duplicate from scratch" (not listed on the Released features) and now we are able to duplicate Sheet with Views (duplicating also the views).
There is any difference between "Duplicate Sheet with Views" and the "Reuse Sheets instead of Duplicate from scratch " in the Roadmap? If so, can you clarify what the difference is? @kimberly_fuhrman-jones @harlan_brumm
@samuelsanf ,
They are one and the same. We just missed it when updating the Roadmap. Thanks for catching that!
-Kimberly
