Building Components as Building Pads
How wonderful would it be if floors, walls, stairs and ramps (even roofs) could have a Yes/No instance parameter to work like building pads. With this function the topography would automatically fill in between foundation and up to the nearest floor and also we would be able to create fully underground basements, tunnels etc. without using 2D filled regions in every section view.
9 Comments
craigh_bim
Please provide a 'check box' (similar for Walls becoming 'Structural' or 'Room Bounding') for Floors to act as Pads and cut the topography below.
Pads are like a specialised kind of a floor but without the flexibility of the floor. Why not simplify the system a bit by getting rid of pads and giving the floors the ability to cut into the topo surface? The UI for this could be implemented as a simple checkbox property that would make the floor act like a pad when ticked but we would still have the ability to shape the floor.
I often create a pad just to cut the topo surface, then I place a floor over the pad and hide the pad. Maybe I'm just odd like that 😉
Tags (3)
It would be great, if this would then work for slab edges an foundations, too!
Gangula2
In the early stage of design, using building pads are pretty complicated and has restrictions. Usually, I use stairs, floors, and ramps to check the position of the necessary building pad. It would be good if I could convert those into building pad.
Tags (1)
pieter7
Perhaps a dropdown in the floors/roofs properties for 'topography interactions' with options like
- none   = does not interact with topo
- cut = cuts the topo but does not fill gaps between the topo and the element
- cut and fill   = cuts the topo and fills gaps between the topo and the element
- covered  = the topo is allowed to cover the element (for example the roof of an underground parking lot)
You could then combine a floor with 'cut' on level -2 and a floor with 'covered' to create a tunnel.
We could then use the already existing tools in roofs and floors (slopes, modify sub elements) to create complicated shapes.
damjanuzelac
I have found three similar postings on this forum related to this idea.
This one has the most votes and it's from 2016., a here are the two other ones.
- https://forums.autodesk.com/t5/revit-ideas/eliminating-pads/idi-p/7203086 (2017.)
https://forums.autodesk.com/t5/revit-ideas/pads-cant-overlap/idi-p/7822123 (2018.)
Clearly there'a an interest in this topic. Autodesk, please look into this idea.
rawezh
great idea.
Status changed to: Accepted
Accepted:
Congrats! We think this is a great idea, so we've decided to add it to our roadmap. Thanks for the suggestion!
To follow the progress of features in development, please see the Revit Public Roadmap and join the Revit Preview Release to participate in feature testing. (Note that Accepted Ideas may not be immediately available.)
The Factory
Implemented
We are pleased to say that this has been implemented in Revit 2025! Thank you for your contribution to improving Revit!
Help | Toposolid Enhancements | Autodesk
 -The Factory
