I have a user who is having trouble saving work on a C4R project hosted on A360. Earlier today, he received the 'missing many elements' error message (see attached screenshot) when trying to open the model. We could not get the file to open at all so I had another user publish the model. Now the file will open, but when trying to perform any save operations (save-to-central or local), we receive an unrecoverable error message and Revit closes.
Other users are currently working in the file without problems.
Any suggestions on where to start diagnosing? I can post journal files if that would help.
Working on Windows 10 / Revit 2017.2
Build
17.0.1117.0
20170118_1100(x64)
Sincerely,
Andy Brack
Hi Andy,
First, on behalf of the C4R engineering team I'd like to apologize for some of the challenges that you've encountered with C4R.
I have some thoughts on how to get you unblocked, but in order to identify the best/easiest path forward as well as to better understand the root cause of the problem I'd like to do a deeper dive and collect some more information from your system. Particularly because the journal attached doesn't quite give me enough insight to have a full grasp of what has transpired.
Some of this analysis is likely best conducted outside this forum, so I would like you to contact me directly via email at michael.brianlee@autodesk.com
Naturally I'll post a followup to this email thread once we have resolved this issue for you.
To get the ball rolling, can you collect the following from the workstation where you are encountering this problem?:
- a zip of the folder C:\Users\jdarcey\AppData\Local\Autodesk\Revit\Autodesk Revit 2017\Journals
- a copy of the file C:\Users\jdarcey\AppData\Local\Autodesk\Revit\Autodesk Revit 2017\CollaborationCache\UKX3QY3N4ZXP\f0e9a2e7-eecd-4fad-bb5e-943add7c546d\d8887c26-9494-4217-b6ab-2fb8ab6d6ef9.rvt
- a zip of the folder C:\Users\jdarcey\AppData\Local\Autodesk\Revit\PacCache\
This will be a pretty big volume of data, so once you contact me I'll send a link where you can post and upload this info and we will work to get you unblocked as quickly as possible.
My hope is that, in addition to getting you unstuck, we will be able to identify whether there is some specific improvement we can make to prevent this from occurring in the future.
Thank you in advance for your help!
Michael B. Lee
C4R QA
