Here is a response from the Autodesk. It also clarifies the question.
Hi Evgeny,
This is Martin with Autodesk Technical Support. Thank you for contacting Autodesk Technical Support. I will be assisting you with this technical support request case. My understanding of your case is that your preparing for an upcoming large project and considering using Revit Server over File-based workshared project for better performance. You asked if it should be faster in comparison with a central file model sitting on a network drive?
That's a great question. And in general, the answer is yes. Of course, when it comes to Revit performance, there are many factors and variables at play: File size, complexity, workstation configuration, server configuration (for file-based and RS), physical location, network conditions, etc.
As a general ballpark guideline, you may want to consider 5-6 the upper end of amount of users for a File-based project. More than that, it may be good to consider either Revit Server or better yet, Collaboration for Revit (C4R). So yes, In general, client-server worksharing is more robust and can handle more concurrency more effectively than file-based worksharing.
Using Workshare Monitor and each user avoiding SWC on top of each other is a best practice. In other words, each user should self-schedule their SWC activity to avoid syncing when they know another user is already doing so.
And Revit performance is of course also impacted by each teams’ or office’s workflows, standard practices, best practices, skill and efficiency of each user, file maintenance, etc. etc. So your millage may vary.
I hope that helps. Please let me know if that answers your inquiry of if further assistance is needed.
Best regards,
Martin Stewart
Autodesk Support Team
