Linked in models not updating
ttaguchiZ8LAH
ttaguchiZ8LAH
I have a Federated model (aka Central model that holds all models in one file) and want to update it to the changes that I have made in each of the other models that are linked in. I saved each model individually and when I try to re link the model into the central model the changes are not shown. I also tried to publish to ACC and link it from there but doesn't seem to work.
AEC_Revit_Lab
Save alone is not enough—Synchronize with Central in each linked workshared model first. Then open the federated model and use Manage Links > Revit > Reload; use Reload From only if its path changed. For a cloud link, confirm it points to the correct ACC model. Hope this helps. If it solves the issue, you’re welcome to mark it as a solution so others can find it more easily.
