Revit Cloud Worksharing Forum
Welcome to Autodesk’s Revit Cloud Worksharing Forums. Share your knowledge, ask questions, and explore popular Revit Cloud Worksharing topics.
Cloud Worksharing Option Without LAN Server
9 REPLIES 9
Message 1 of 10
mluther12
848 Views, 9 Replies
Hi All,
My apologies if I am misunderstanding how cloud worksharing works - that's why I'm here!
My office (4 Revit users) is currently using Dropbox to store our models. As many of you may know, Dropbox doesn't allow us to truly work on a model simultaneously. We have to create detached local copies and sync them to the central model. This creates issues for us, especially when rendering using Enscape (applied materials cannot be loaded when another user opens the model).
Setting up a LAN server is cost-prohibitive for us. I'm wondering if anyone has any advice on how we can go about worksharing without having to get one installed?
Thanks!
Matt
Labels (1)
9 REPLIES 9
Message 2 of 10
Yien_Chao
in reply to: mluther12
if a LAN server is too pricey.. i dont see any other solution than bim360 or ACC with Design Collaboration.
So you will be able to work and sync on cloud. you will need as many licence as users.
https://www.autodesk.ca/en/products/bim-collaborate/overview?term=1-YEAR&tab=subscription
Message 3 of 10
mluther12
in reply to: Yien_Chao
Thanks for the response! With BIM Collaborate Pro, do you know if the central model will use the same file path no matter which user opens it? That's the issue we're running into with Dropbox. We can't store Enscape materials in a common model because the file paths are still unique to each user (i.e. C:\Users\User1\Dropbox...).
Message 4 of 10
Yien_Chao
yes it will.
Message 5 of 10
mluther12
Thanks, I'll give the trial a try!
Message 6 of 10
Lance.Coffey
For Revit Render Appearances, you could still run into issues with pathing, but should be able to address this using the Additional Render Appearance path feature.
For more info on this, see the article: Sharing material appearances with other Revit users
Lance Coffey
Technical Support Specialist
Message 7 of 10
mluther12
in reply to: Lance.Coffey
Thanks for the tip! Could this work using our current Dropbox setup?
Message 8 of 10
Yien_Chao
just dont use dropbox for that. you will have more issues than benefits.
Message 9 of 10
Lance.Coffey
@mluther12 Yes, the Additional Render Appearance path feature is setup to allow render appearances to be found when they are located in different locations on different systems (this could be used with render appearances stored in a DropBox path).
However, as @Yien_Chao mentioned Dropbox would give a poor experience for multi-user collaboration/worksharing compared to other options.
Lance Coffey
Message 10 of 10
mluther12
Got it. We are exploring other options but this should help in the interim.
