A360 Mange A360 Models not working
Message 1 of 9
I recently installed a Revit security fix application called revit_2017_0_3. Now i cannot access my manage A360 files from revit. I am working in Revit 2017 version/build 17.05.503.0/2017.0.3 (see above highlighted)
Replies (8)
Message 2 of 9
kadmonkee
is the site down?
sometimes there is an interruption in service.
check this web site to see
https://health.autodesk.com/
If there is any information shared that is of value please give Kudos
If a solution is provided by any posters please mark them as Solved to benefit everyone else.
thank you
Message 3 of 9
Good question...let me check...The site is up and running
Message 4 of 9
kadmonkee
are you able to log into your team hub through the Collaboration 4 Revit tools?
can you log into the web browser for your team hub?
thank you
Message 5 of 9
Yes I can login to my hub for all my projects.
Message 6 of 9
kadmonkee
it seems to be something on Autodesks side.
many others are experiencing different issues to the same theme
BUGGY application.
thank you
Message 7 of 9
AdamPeter
@Anonymous, is your version of Revit different from your version of C4R.  If there is a mismatch it's possible to see the error you are seeing.
There is a knowledge base article HERE with installs to the latest versions if you need them.
Hope this helps,
Adam Peter
Customer Program Manager
Message 8 of 9
Good observation. I tried those link but the download option Is greyed out.
Message 9 of 9
