Hello!! Whenever i try to use the Zoom Sheet Size it seems to not be at the real size. I tried measuring it from the screen and it show the element smaller than it should be if printed. This happens in RVT 19 and 21 and my monitor has a 2560x1080 resolution. I don't know if i'm crazy but, i'm pretty sure that this worked properly on my old computer (with a 1920x1080 resolution). Is there a way to calibrate this?
So you are literally measuring the display on your monitor and comparing it to your printed hardcopy?
Are you using a tape measure or a wooden ruler?
https://www.howtogeek.com/304036/HOW-TO-ADJUST-SCALING-FOR-DIFFERENT-MONITORS-IN-WINDOWS-10/
https://fotoworkspro.com/pages/how-to-get-your-prints-to-match-your-screen
Yes and no...
I use the Zoom Sheet Size to check if something will be too big or too small on the sheet before printing, but i do this just visually because a long time ago i cheked to see if it was at the right size, thus not requiring to measure every time.
On my old pc, as i said, this worked as intended. Whatever i've drawn had matched the exact size as if being printed.
Now, om my new monitor (that has a bigger resolution) this is a bit off. Let's say that i drawn a 1cm line. If i set the view to 1:1 and use the Zoom Sheet Size, this line should be the exact 1cm if i measure it with a ruler. However, the drawing seems to be a little smaller.
This doesn't have to do with the view scale, as i'm using a scale ruler (see below) and this happens in whatever scale that i use.
For some reason, if use the Zoom Sheet Size and then scroll just a little bit (just one step closer) it seems to be at the right size.
This is not a major issue but is kinda depressing that it worked flawlessly before. I think that maybe this resolution is not supported yet for this command.
