Wrong elevation in ifc
I have a problem I cant figure out. I have a building in revit. The 1st floor is placed at 2,5 meters above sea Level. Level 2500. My Project base point and my survey point are in the same Place - 0,0,0 . When I export ifc and open the ifc in solibri model Viewer the walls show Global bottom elevation: -2.5 m. In other Words 5 meters too low. What is wrong? How do I fix this? Where are the PBP and SP supposed to be? Should they be clipped or not? Should the Levels elevation base be PBP or SP?
While you exported your file to ifc,
Include IFCSITE elevation in the site local placement origin Option was checked or not?
if not can you try to export your file after checking it on? as indicated in attached snap.
sai.jayaraman86K8C
Thanks Guys this helped to resolve my issue
