Announcement: We’re aware of an issue affecting starting a new topic from category pages and creating new blog posts. New topics can still be started directly from the relevant board. Learn more here.
Writing Key values in Door schedule from Excel
Hi ,I am using key schedule for Door hardware’s sets in my door schedule. But, the problem is I have more than 5000 doors, So choosing key in Door schedule for each door one by one manually takes lot of time. I can do writing values from excel to Revit for all other parameters using either dynamo or other plug ins. Unfortunately, excel to Revit is not working for choosing the key in Door schedule. Is there any way you can suggest me to automate this step..Thanks a lot in advance.
onBIM-Consulting
Dynamo is a very good way to solve that. Do you tried it?
onBIM-Consulting
The key is a instance or type parameter?
onBIM-Consulting
Can you attach a image of your Revit schedule?
When I need to do this I create a normal door schedule and start grouping them by Room functions so that I can assign the hardware key to a bunch at a time. Similar for other criteria such fire rating etc.
hi,
yes I got it in dynamo.
