Wrapping wall, after making angle cut
cadedu22
cadedu22
After cutting wall angle with "Edit profile" how can I make Wrapping for cutted part?
Like this:
RDAOU
@cadedu22
Wrap as in the built in wall wrapping at the top is not possible, but it is possible to achieve a similar in different ways
  • Considering that you have a single layer wall simply Paint it as per GIF 1 below...
  • OR add a sweep or a swept blend to cap the top >> give it same material >> finish sketch >> align pattern and join Geometry - See GIF 2 below
  • You can do the same as option 2 above using a Mass
Looks like you already did. Are you wondering how to align it properly?  TAB-Select the Model Pattern and use the Rotate Tool.
https://knowledge.autodesk.com/support/revit/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-C...
cadedu22
@RDAOU
Yes that's what i tried to achieve.
@barthbradley
Photo was edited to show what result I wanted, I couldn't find solution. What posted @RDAOU is solution and result what I tried to achieve.
Yeah, In photo it looks like I already achieved it, despite fact that it's quick photo edit (i guess it's good edit if it's believable :)).
&&&Thanks for help.
