or place an "architectural" column over the structural column. Arch Columns
can have finishes applied, and will inheirit the properties of a wall if
they intersect.
"waltermullett9350" wrote in message news:6355011@discussion.autodesk.com...
Because concrete structural columns are just that - concrete and structural,
you will not be able to change them. You could wrap them with a brick
veneer wall. You could also edit the structural column family changing the
material to brick and calling it a brick structural column and re-loading
it....If you do that - change the structural material type as well in
properties.
