Workshare Files and Links
適用対象外
978件の閲覧回数
3件の返信
メッセージ1/4
適用対象外
Hi there,
Was wondering if I could get some advice on Revit Files.
I have a file set up for the Facade of a building - within this file, I have linked in three files for the interior of the building:
1. Level 1
2. Level 2
3. Level 3-24
I now need to create the landscaping and rather than put this into the Facade file and overload it, I have created a new file for the landscape. I have then linked in the Facade File.
What is happening in my Landscape file is the Facade file that I linked in is also bringing with it all the linked files  (Interior Level 1-24). In my landscape file, I now have multiple sets of grids that I can't control.
Any advise would be greatly appreciated!
0 件のいいね
解決済み
979件の閲覧回数
3件の返信
返信 (3)
メッセージ2/4
SteveKStafford
解決済み
You probably don't really need one model per floor if this is one building. Revit is designed to model the entire building in a single file (per discipline typically). In fact it's quite inefficient to model floor by floor by comparison. Even when a floor design is used on more than one floor it gets quite obtuse to treat the same floor model as unique on a different floor when subtle differences creep in, which happens in every project I've ever encountered.
It is however quite common to model site and building separately, I do it for a number of reasons but primarily for real world versus project world (shared coordinates/survey relationships with site).
That written, any link will bring along the levels and grids with the 3D building elements. We generally use Filters to isolate them and turn them off with V/G and View Templates. I control them by naming the levels and grids uniquely so a filter can "see" them as unique/different from those in the hosting model. If I control all the models I'll use a discipline prefix. If I don't I use a name that is just different from the names used in the other models.
Some people rely on specific worksets to turn them off but I find that's too prone to user error, not assigning all the grids or levels to the correct workset. Their type names aren't nearly as likely to change or fail to work with Filters. If they do then it's really easy to fix and completely up to me, no waiting for people to fix their models.
Steve Stafford
メッセージ3/4
nmarcelis
@SteveKStafford Excellent answer of best practices.
Revit Certified Professional Architecture, Structure and MEP.
0 件のいいね
メッセージ4/4
適用対象外
Thank you @Anonymous that is great
0 件のいいね
