Greetings,
We are structural & architectural teams using the same revit central file
The problem is when the architectural team started to "for example" create block wall, by default if there are structural wall beside, it`s stretched to attach the new wall (as shown attached)
So i started to create worksets for the structural & the architectural elements to protect the sturctural elements from editing by the architectural team but we faced some issues:
Thanks & Regards
Hi....
Refer the below image, select the wall which you don't want to stretch/join with other, you can see a small blue ball on wall end once you selected the wall, right click on that and hit disallow join. It will not allow the wall to join with other wall and you can stretch the wall length as you want. Think it will help you.
Hi try this,
Open your worksets window, and create two work-set for structures (example: Structure 1 and structure 2), select Structure 1 and check the "family" checkbox under Show (Refer the image below). Once you activate the family check box you can see various families from all category, here you can give/cancel permission for different families for Stuctures 1, do the same for Stucture 2. So you can create Structure 1 work set for wall and Structure 2 work set for column beam etc.,
