Work set
Work set
civil_hari3010
Work set
civil_hari3010
Hi
Greetings!!!
I have created the central model file with two team members.
All the four rows in the work set dialog box(two default rows and two created team members) ll be non-editable since it’s a central model file.
Then I am trying to make the local file.
I have opened the central model in another Revit window, to make member 1 as active workset, then I saved as member 1. so that he can work in his assigned portions.
Later, I created second local file for second member, Wen I go to workset to make member 2 as editable, I couldn’t make it. It’s showing already member 1 is editable.
Main issue is that, I want to request the member 2 for editing some of his portions. But what’s happening is that, I can able to edit the member 2 portions without even requesting him. I used to do it in lower versions without any issues, now I couldn’t do it in 2023.
You don't need to make any workset Editable for any users unless you want it totally inaccessible by others.  Leave all worksets Non-editable then any user can borrow a workset to work on (and it is handled automatically by Revit).
By the way, the terms Editable and Non-editable can be confusing for new users.
