Message 1 of 13
Work plane / reference plane set on pitched roof
- Mute
- Permalink
- Report
I need to work on the lower end of a pitched roof which is visible in both level 1 and level 2 plans, what I exactly need to do is to add crickets with roof tools. I set work plane/reference plane on this roof , but I keep getting the following error messages whenever I try to use roof tool in both plans,
"The work plane of this view cannot be used for this operation. This operation should be performed in another view or the work plane of this view should be set to a level by using the work plane command."
I want to create a roof that aligns with the pitched roof not the level. Do not understand what I should do to make this happen?
However when I test with wall tools, no error messages.
