Word import into Revit
MHArchitects
MHArchitects
Has anyone had any luck in finding a way to import a word doc with tables into Revit 2017? Every Architect in America has to include a Building Code Summary in their Drawing Set. It's a crying shame that as much money as the users pay to maintain their Revit license, that Autodesk can't find a way to do this as well as many, many other user needs that needs to be added to Revit. I've tried pasting into Autocad and inserting the cad file into Revit with absolutely NO luck. Nothing is transferred into Revit.
Replies (14)
matthew.d
Hi @MHArchitects,
Welcome to the community!
Sorry to hear about the issue. I see that you probably went through the importing Microsoft Word into Revit document. It seems like you are having trouble with the tables through. I haven't tried this specifically yet, but I would suggest making a schedule in Revit that finds no elements (see article) to the same dimensions and try pasting. Let me know how this goes. There are a couple of apps that can take excel tables to Revit, is there a reason it needs to be word?
Matt DiMichele
Autodesk Product Blogs | @ADSKCommunity Twitter
Likes are greatly appreciated. Everyone enjoys a thumbs up!
Please Accept As Solution if this resolves your issue, to help others benefit and locate it.
CADmonkey_UK_Building_Services
Nice hack!
The OP could also consider investing in making the document, tables,etc. once, in Revit, and then their troubles will be over.
Another option would be to generate a PDF, insert it into Autocad, explode the PDF into Text objects and then insert the DWG into Revit.
I
Please select the Accept as Solution button if my post solved your issue.
Intel 7740x - Quadro 6000 - 32Gb RAM - CADmouse - Logitech G710
mmcintosh-ral
One answer your question, why Word and not Excel?
Word is the format that our state (North Carolina) provides for the Building Code Summary information that Architects are required to provide with Construction Documents.
mmcintosh-ral
I found a method to do this. It's a bit clunky, but it's working for now.
1. Format word document pages so that each page, if cropped, would fit together with the others on your Revit sheet at full size.
2.  Save the word document as a .pdf
3.  In .pdf editor (we use Bluebeam), set the image export resolution to 600 pixels/inch. In Bluebeam this can be found at: Settings> Preferences> Import/Export> Images> Export as Image Options> Resolution (I also have "create multi-page tiffs" checked in this dialog).
4. In .pdf editor, export to .png file (.jpg will probably work too).
5. Revit- in a plan view, scaled 12"=1'-0", Insert> Import> Image (the reason for importing into a plan view is to have access to the crop region. The word document I'm using has wide margins, and will only fit on the sheet if the margins are cropped.)
6. Revit- (not required) to verify the size of the imported image, draw a filled region snapped to the imported image edges and pull a dimension.
7. Revit- Select Image, Modify> Scale, scale by numerical input and enter the decimal result of 72 (Revit Import Resolution)/ 600 (Original Image Resolution), click cursor in view to activate the scale command- the image will shrink and move. (this method was described in a 2-16-2010 AUGI post by Alex Page)
8. Revit- (not required) to verify the size of the image resize the filled region to snap to the smaller image edges.
9. Revit- Repeat steps 5-8 for each word page of the code summary, and arrange views on a sheet.
10. Updates: make update in Word, save as .pdf, export to .png (overwrite the existing files), unfortunately Revit does not have a live link to these files.
11. Update in Revit: Insert>Manage Images, select.png file, click reload. unfortunately, each image must be selected and reloaded individually. after reloading the updated images, click OK and the images will update in your views.
Additional notes- I'm using this method in a Code Summary project file that has linked models for multiple buildings in the design project. I keep all the word files together in one directory, and have subdirectories for each set of .pdf+.png files. I set up image views and sheets for a project with seven buildings, and have been able to reuse it on two additional projects. When we were in AutoCAD I had a pretty nice attribute block sheet that matched the NC required building code summary formatting (we saw it turn up in documents by other firms, so I think it's a fair claim)- some discussion threads have recommended doing something similar in Revit, but for right now updating code info in the word files and relinking the exported image files in Revit seems more efficient.
mmcintosh-ral
On a related note-
We needed to update our Code Summary Sheets in AutoCAD for the new updated version of our State Building Code. Using this same method is quicker than updating our old AutoCAD attribute blocks.
I used basically the same process (.png files full size in model space, in cropped 1:1 views in paper space). The only big difference is that the AutoCAD file must not be open when resaving the .png files. This is because AutoCAD (unlike Revit) maintains a live link to the .png files, and therefore locks them while the AutoCAD file is open. Closing the AutoCAD file to overwrite the .png files is still quicker than the Revit workflow since all of the .png files update at once on opening the AutoCAD file.
benhagerman
I do all of my code calculations in excel and use Ideate Sticky to bring them into Revit. works very well. they also have Bim Link that will pull out Revit data to use in the excel formulas.
mmcintosh-ral
That sounds great.
The reason we're linking the word document is because our State requires the Code information to be displayed as it's shown in their Word document. We've found it's easiest to just use their Word document rather than recreating their formatting with other software (like we did with our AutoCAD attribute blocks previously).
mmcintosh-ral
Here's an add-in program that will also link word documents into Revit.
Axiom Microsoft Office Importer
https://www.axiomint.com/microsoft-office-importer-revit/
I've seen a demo, and am hoping my company will buy licenses for us because it is much more efficient than the workflow I outlined above.
vpage200
I agree that Revit could make Word and Excel "pastable" for the amount of money we spend on the program. Revit, itself is already expensive, then we have to spend yet another amount for an app like axiom. I am a new convert to Revit, but wonder if it is worth it for all the add-ons that is necessary.
Nicovanerm
Observer
Observer
I agree, with what I pay for 25 licenses I would expect these sorts of problems to be resolved by Revit, not by me!
I export Word or Excel or whatever to PDF and link/import PDF in Revit.  They are updated automatically with Reload when the sources are updated.
benhagerman
Sticky is a third party add-in that handles this very well. I have no affiliation to Ideate, we have used it for several years and they have now added the link to MS Word feature.
https://ideatesoftware.com/ideatesticky
With Ideate Sticky, Revit professionals can also:
  • Import as a static element or as a dynamic link
  • Update non-BIM consultant data from MS Excel into Revit
  • Link Excel, Word and PDFs to Revit projects
  • Represent subtotaled data or matrix data
  • Use Ideate BIMLink to export model information to Excel for editing and then import from Excel into Revit, and then use Ideate Sticky to display that information in Revit
RobDraw
Maybe you should stop buying it until it fully meets your requirements.
Rob
Thanks for the info that maybe useful to others.
