wish : be able to change default to Miter corners/joints
leilani.gnall-gregory
When creating "linework" to see "walls above" or "walls below" its best to have those "walls" with Mitered corners, so that you only have ONE line to match, with corners defaulting to "butt", i have to change every corner, this is time consuming, and if left as "butt" joints you have to identify multiple lines to finish the corner.
My WISH, is for Revit to allow users to set the DEFAULT joint as what ever works best for their drawings.  in my case, that preference would be "miter"  wall joints.
RobDraw
The IDEAS forum is where your wish belongs.
Rob
You don't have to change wall joins one at a time. When you use the Wall Join Tool, hover over one corner and press the TAB-key once and see the magic happen.
