Wire Mesh Wall
Wire Mesh Wall
raresh1905
Message 1 of 11
Wire Mesh Wall
raresh1905
hi, i wanna create a mesh on the building that will close some of the facades and balcony, to look something like the photo below. How can i create it? Thanks!!
Replies (10)
Message 2 of 11
RDAOU
@raresh1905
That is modeled using a Curtain Wall System; and the Mesh is applied as material to the Curtain Panels
  1. You either create it using a custom pattern applied to surface
  2. and/or from an image assigned to its Rendered Appearance in Material browser
Apologies, I am too reluctant on elaborating more on this reply since I am somewhat sure that it will be ignored similar to your other posts. Should you require further assistance on this one; you should revisit your older posts and show the lady and two gentlemen who helped you some appreciation and gratitude by marking their helpful replies as solution.
http://forums.autodesk.com/t5/revit-architecture/revit-worksets/m-p/6268057#M113655
http://forums.autodesk.com/t5/revit-architecture/concrete-railing-for-stairs/m-p/6238290#M112504
Message 3 of 11
raresh1905
hi,
revit has the mesh material or should i download it from somewhere else?
i check on curtain panel but i dont find mesh
how do you create that 2 mullions? its another curtain wall place as a curtain panel?
and sorry for the other post, i go for thanks in privat messages becouse at that time the button accept solution doesn't work for me, and for kudo i click like 3 days in row for it to be accepted.
Thanks for helping me!
Message 4 of 11
raresh1905
i got it i think, i set up the panel as solid and edit the material from aluminium with cutouts, did i do well?
but i got one problem, i change some of the properties after i duplicated it and when i change the appearance i will change on both material so i can not have a standart aluminium and a custom mesh from aluminium
Message 5 of 11
RDAOU
More or less yes I think you got it...however, I am confused on the last part. I did not understand what you mean!!!
What did you duplicate?
Where are you changing appearance?
Which both material change?
If you clarify a bit or post an image (screenshot) then I can understand what you are seeing on your screen and what you are referring to
Message 6 of 11
raresh1905
so first i click on edit type on that panel..
from Type Properties i go to Material click on more open the material library click on aluminium , right click on aluminium select duplicate.
then i go th appearance and check the cutouts click ok.
when i modify the new material that i made the base material in this case Aluminium take the same parameters as the new one and i dont want that.
Message 7 of 11
RDAOU
  • Before you go further to the Material > Duplicate Panel and call new one "example: Panel with Mesh" or something else to your liking
  • When you duplicate the material "Aluminum" name the New one "example: Aluminum with Cutouts" (in your image you are still modifying the original material ... hence it will apply to all Aluminum already placed in the project
  • Then make sure to select the duplicate/new material "Aluminum with cutouts" (not the old default one)
  • then go to Appearance tab for the new material not the old
> then i go to appearance and check the cutouts click ok.
  • Before you change appearance >> up in the right corner > Duplicate Asset > call new "example: Satin with Cutouts"
  • Now when you modify appearance it will modify only the appearance for the new asset which is used by the new Material...the original material called Aluminum should remain intact
Message 8 of 11
raresh1905
i do exactly as you sayed except  this part
"Before you change appearance >> up in the right corner > Duplicate Asset > call new "example: Satin with Cutouts"
i duplicate and now its all right, thank you!
Message 9 of 11
raresh1905
@RDAOU i got one more question i set the border to circular and chouse the join condition border and vertical but the border doesnt weld right on the corners.
Message 10 of 11
RDAOU
You are more than welcome 🙂 and thanks for revisiting your old posts and marking Lisa's and Constantine's replies ...this will help other forum members find those answers easily when they have a similar question to yours
If you need any more help please do not hesitate to ask
Message 11 of 11
This mesh is too tight to install on the balcony because it will lose view and tighten ventilation You can refer to the photo here luoi-an-toan-5.jpg
