Windows: Schedule parameter
4 REPLIES 4
XXalessio.amodioXX
352 Views, 4 Replies
Hi all,
I have issue as described in pic. Any idea?
4 REPLIES 4
Can you please explain what is it that you want to do? What is the question?
Andrej Ilić
phonetical: ændreɪ ilich
MSc Arch
Autodesk Expert Elite Alumni
I create one family Window.
I have prepared  parameters that drive the panel widths and, consequenlty , symbol lines that show if panel is fixed/hopper/swing.
For firefighting BoQ I need to fill escape door width/height just the openable panel (Type of a family).
I want all windows in same schedule but once filled the W1 parameter it will be shown indipendently if the panel is fixed or swing one.
I DO NOT want to show parameter W1 if panel is fixed because confusing.
You can use a yes/no parameter in example, but hide this in your schedule. Then instead use a calculated field to show the text you want if it is turned on and empty/space (" ") if turned off.
Calculated valueCalculated value
It is not a proper solution but you gave me inspiration .
I can use it as a formula inside revit family itself.
